New P/S Hose Look Too Loose? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-10-2013, 11:08 AM Thread Starter
meanjean's Avatar
This is a new hose that runs from the P/S pump to the Hydro Boost. It’s a pressure hose. To me it looks too loose but I have not been able to run the truck yet as I am doing some other turbo work. Maybe when there is pressure back in the line it will not move so much? I actually returned the one I bought from Advanced Auto, bought another one from Auto Zone and both were the same. Hooked the factory one back up and it too is loose like the new ones. Here is what’s stumping me, when I pulled the stock one off it wasn’t loose like this, now it is?
Am I missing something? The hose is as tight as it goes.
Loose Hose - YouTube
2000 F-250 SD CC 4x4.
35" Nitto Terra Grapplers, MBRP 4" exhaust,
Auto Meter Phantom A-pillar gauges,
S and B air filter, Superchip 1705,
4" Cage lift kit, Leer Canopy
meanjean is offline
post #2 of 6 Old 03-10-2013, 10:09 PM
Drive the truck and see if it's leaking. If it is, there's something to deal with, if it's not, there isn't.
Mike
  • '99 F350 CC 180,000 miles so far. Edge Evolution programmer, AFE intake. 8" suspension lift, 3" body lift, 37" Hummer tires.
  • '96 F350 CC Dually KIA 663,000 miles at it's death
RopinandRidin is offline
post #3 of 6 Old 05-03-2013, 06:51 AM Thread Starter
meanjean's Avatar
No leaks. After I started the truck and pressure was added from the pump it is tight just like before.....minus the leaking.
Thanks
meanjean is offline
post #4 of 6 Old 05-03-2013, 06:58 AM
timmyboy76's Avatar
did you remember to install the new "white" shim gasket?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 6 Old 05-03-2013, 03:15 PM
Jakeman711's Avatar
That gasket usually comes already installed on the hose. This has been my experience anyway. I do however get my hoses from NAPA.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #6 of 6 Old 05-04-2013, 09:18 AM Thread Starter
meanjean's Avatar
The gasket was already on the hose when I bought it. I picked up the hose from Auto Zone.
meanjean is offline
