DEALER ONLY?
Ok I need to replace the cap on the fuel pressure regulator. I think I over tightened the fuel delivery line to the fuel bowl, and now the little aluminum cap has a crack and is leaking diesel fuel. I simply need the cap that is bolted to the fuel bowl by the 2 torx bit bolts. I'm like 95% sure that it is a "dealer only" part because no parts stores have the part. My question is, how much can I expect to spend on this little aluminum FPR cap? I have the cap off, so I'll try and post a picture of it if you guys arent sure of what exactly I'm talking about.
I just removed my regulator so send me a pic if it the same maybe I can help out.
I switched to a electric system |
There are 2 kits- 1 has the 2 fuel lines hooked together with the nut on it that screws onto this regulator housing. The other is the lil housing you are looking for. It only comes as a kit including the housing,spring,jet, and torx screws. I think I paid 99 at the dealer. I broke mine too.
di sells it for like $10 i belive for just the cap its on theyre web site check it out
I wonder if my local Ford dealer will sell me just the cap. I only need that damn aluminum cap, nothing else, and I need it tomorrow a.s.a.p. because we have some serious snow coming over night and I need to do some plowing... but right now all I'm doing is leaking this liquid gold that sells for $3.60/gal.
im betting even if the dealer would sell just the cap that its not a stock item and will have to be ordered
