how much voltage should glow plugs draw?
When my truck is cold and I go to start it, how much voltage should the glow plugs be drawing? My Edge when set to volts, does not change. The glow plug relay shows 11 volts going in and 11 going out to the plugs, but I'm wondering if the plugs are actually working. I have a 1316 code and am wondering if there is a short somewhere causing the code and the glow plug system to not work. anybody have any ideas? There are too many new parts on the truck to mention but it does have 8 new glow plugs and they just dont seem to be working. I can plug the truck in and it starts right up.
this issue is going on 3 months now and its getting expensive and old.
Put a meter on the relay unless the edge is the name of your meter? Im assuming thats the edge tuner?
I set my edge evolution programmer to volts. The relay is working, 11.4 volts on one side and 11 on the other. I'm just wondering if all that voltage is actually getting to the glow plugs. Also today I unplugged the air intake heater and wrapped the ends in electrical tape. Somebody told me their air intake heater was shorting out and was drawing too much away from the glow plugs, don't know if anyone has heard of that happening, just thought I'd give it a try anyway. I'm still getting the 1316 code though. Does that mean my idm is bad? or just that there is a short somewhere between the idm and injectors?
Here read this 7.3 glow plug system diagnosis Test your relay and gp's out. I doubt your aih is doing that as its a different circuit. I can't help you with your idm code
I know this is not what you are after but I'm not sure what it is as the way you ask don't add up. So hear is as close as I can get and some electricity 101 to help you out.
Everything in the truck is 12 volt, so everything runs on 11 to 14 volts depending on how much is available to be had in the hole system at the time. All the volts do is move the amps to the work and the total amount of work going on is watts, volts X amps = watts. So the amps that do the work and glow plugs pull a lot of amps, about 8 amps per glow plug or 100 watts worth of 12 volt power. Thats about 60 amps for all 8 of them or 800 watts of total power draw when on. The only way to know what the real world draw is would be to install an amp meeter in line between the battery and gpr. But the only reason to do that would be engineering work. For repair work testing all you need is a test light. By hooking the test light to the + side of the battery you can probe the glow plugs one at a time, just unplug the wire from the GP and probe it with the light. If the light comes on full the GP is good. I am not sure on this but I think you can probe them one at a time at the valve cover gasket plug, if I'm wrong on this someone will set me right I hope. I will check that on my truck tomarow any way, I like to know for sure. Now I hope that helps and if not I'm glad to confuse you more. |
