99 wont start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-13-2008, 12:35 PM Thread Starter
99 wont start
I have a 99 f 250 that fired up this morning and then it died. It had blown a 30 amp fuse. The owners manual says that it runs the pcm relay coil,fuel heater, wastegate solenoid, and the injector driver module relay coil. I put new fuses in and when I turn the key on it blows them instantly. I was wondering if anybody had any ideas.
71fordbronco is offline
post #2 of 4 Old 01-13-2008, 12:40 PM
ADMIN AND TECH
SCUFFY828's Avatar
the fuel heater is shorted , unplug the heater on the backside of the filter housing , white 2 wire connector, leave it unpluged and youll be fine
ITS STOCK
SCUFFY828 is offline
post #3 of 4 Old 01-13-2008, 12:48 PM Thread Starter
THanks I just searched the forum guess I should have done that first I will go give that a try.
post #4 of 4 Old 01-14-2008, 02:29 PM
2whlfreak's Avatar
When you goto replace your heater be sure to get your part from your local IH parts man it will be a fraction of the Ford cost.
2whlfreak is offline
