how to check/add oil to my hpop - Ford Powerstroke Diesel Forum
Old 01-12-2008, 04:43 PM
I have an 02 with a 7.3 and it will crank but wont start. I suspect the hpop but i dont know how to check/add oil. can anybody help
Old 01-12-2008, 04:46 PM
have you just checked the oil in general? my friends dads truck was low and would not start. or it could be the Cam Sensor. sorry i cant help on the HPOP.
Old 01-12-2008, 04:53 PM
you can check and refill the hpop through the small hex screw or bolt in the top of the resivore
Old 01-14-2008, 05:48 PM
Thanks I was able to get it started just by adding a little oil to the resevoir now how do I get it to stay in the resevoir. It just drains out when it sits overnight
Old 01-14-2008, 06:01 PM
It sounds like to me that the check valve is stuck or shot.
Old 01-23-2008, 05:46 PM
where is the check valve?
I have the same problem
