I have a 2000 psd with intake, exhaust, and TS 6 position chip. My problem is that at idle my truck sounds like its running out of fuel. This only happens sometimes, not all the time. I replaced the fuel filter about 15000 miles ago, is it time to change it again?
Running outta fuel can actually be running out of fuel, fuel pressure, injector control pressure, or electrical firing of the injectors. So kinda need more info to narrow it down.
I replace my fuel filter every service because what you don't realize it that filter has hundreds if gallons of fuel running through it in a 5000 mile interval. The oil filter only has 4 gallons to filter.
I hooked up a code reader and it threw the cam sensor code. I replace it and everything is all good now. Thanks everyone.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
