IMMEDIATE HELP NEEDED!
I just did the fpr shim on my 96' and didnt see much of a difference but the main cause of not seeing a difference is a clogged or dirty screen between the fuel header and fuel filter housing (on top of the engine) my question is what is the best way to clean this screen? im seeing a lot of crud in the screen that needs to come off but not sure the best way to actually clean it because theres VERY limited space.
PLEASE HELP!!!!!!!!!!!!! |
qtip, just rub over the screen alittle.
oh i didnt see you on here anyway the screen is not actually on the white piece correct but on the housing i can see alot of crud but a qtip will do a good job????
yea, its just used like you use a rag on something. the junk should just wipe off.
i'll be on for another 30 min or so, and will be back on later tonite (hopefully) |
alright thanks alot im gonna go do that now
well?
yeah i used sea foam spray, qtips and a small flat head screw driver. mine was plugged to the gills when I bought my truck.
