Block heater puzzle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-08-2008, 08:16 AM Thread Starter
Block heater puzzle
My truck leaks like crazy when the block heater is plugged in. I came out one morning last week to find a huge puddle under the engine (the length of the block, about 12" wide) It smelled like engine oil, but the dipstick showed no difference.
Lately, I've also been smeeling fuel, regardless if the truck's been run or sitting for hours. Both of the hp oil pump lines are wet, and it looks like a small amount leaking around the filter cap. The valley underneath is coated with grime and looks wet, as well. I haven't taken the Powerstroke cover off to inspect yet.
F250 sold.
nc1500 is offline
post #2 of 7 Old 01-08-2008, 10:06 AM
well plug it in and crawl under there every 30 minutes and see if you can find something leaking. that's the only thing i can think to do. maybe a tech will jump in here..........
later,
bishop
USMC 2002-Present
2002, 7.3, CC, LB, 4x4, Pro Comp 6.5inch (really 7.25inch), Super Swamper TSL 36x12.50x16.5, centerline wheels, mud, Cobra CB, 10ft whip, mud, straight pipe dumped in front of rear tire, 10K mod, zoodad, mud, herculined custom front bumper and lined bed, etc.
marinepowerstroke is offline
post #3 of 7 Old 01-08-2008, 11:19 AM
adfields's Avatar
Is it slow to start after leaking? Also was the puddle coolant or fuel?
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
post #4 of 7 Old 01-09-2008, 01:37 AM Thread Starter
The truck starts fine. The puddle was oil. I've never heard of the block heater causing this sort of problem. It only seems to happen when the things plugged in, although I'm sure this is a symptom of a bigger problem and it leaks all the time (just in much smaller doses).
F250 sold.
nc1500 is offline
post #5 of 7 Old 01-09-2008, 02:08 AM
todd's Avatar
oil flows better warm sounds like your lines are leaking filling the valley and and just flowing out the valley drain overnight better now cause its plugged in and warm
traded it for an 06 dodge sorry
todd is offline
post #6 of 7 Old 01-09-2008, 04:33 AM
Is it even worth it???
ABOBB's Avatar
I had a similar problem. Once I'd started plugging my truck in for the year, I had to crawl underneat and tighten the oil filter!!!
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #7 of 7 Old 01-09-2008, 10:26 AM
adfields's Avatar
I think TODD is on the right track hear. You better find the leak as when I had a small oil leak last month and put off finding it I had to call a tow truck once I did. In my case it was an hpop O-ring leaking a bit but then it gave out all at once and pumped all my oil out in less then a half a mile.
Check the 2 lines on the side and 1 plug on the back of the hpop for your leak. I think you will find evidence of oil spray around one of them. If one is bad replace them all! They are not plane old O-rings, I got mine from Ford and it was $38 for 3 O-rings. What a good deal, ,,,,,,,,,,,, for Ford.
ANDY
The Wifes Ride:
adfields is offline
