Stalling? Restarting - Ford Powerstroke Diesel Forum
Old 03-04-2013, 09:09 AM
Driving down freeway yesterday and it was like someone had reached over and shut off key and then turned back on almost instantly. No SES light and truck runs fine. This happened like 3 times in 100 miles. It would occur when I would have to take foot off gas to slow down for slower car and then put my foot back on gas pedal, Not kicking it down just resuming original speed around 60 -70 mph and in O/D was not towing anything. 2001 f-350 7.3 super duty
Mods / AIS / severe duty air filter
Old 03-23-2013, 05:57 PM
Re: Stalling? Restarting
I am having the same problem with my truck did you ever figure out what was going on?
Old 03-24-2013, 03:28 PM
No I went ahead and changed cps but still does the same thing. I get code for low boost ? but I dont think that has anything to do with the problem. I have a leak At up pipes so thats probably the low boost issue
Old 03-24-2013, 03:49 PM
The motor actually shut off or just went to 0% throttle? Could be throttle sensor.
Old 03-24-2013, 05:51 PM
tach needle drops to zero and bounces right back like turning a light switch off and right back on it happens in a blink.
Old 03-24-2013, 06:15 PM
Could be CPS still, possibly IDM, bad PCM connection or PCM, or even UVCH.
CamshaftPositionSensor
InjectorDriverModule
PowertrainControlModule
UnderValveCoverHarness
Old 03-26-2013, 08:07 AM
wouldn't these items throw a code?
Old 03-26-2013, 08:47 AM
Mine threw a code then the ses light went out. Has done it since
Old 03-26-2013, 03:39 PM
You'd think they would. But not always for exactly that item. More like a subitem.
You've got a stored code.
Old 03-28-2013, 08:26 AM
Well problem is getting worse gradually, now it shuts off for a couple seconds and starts back up. No ses, no codes, no smoke, no engine shake nothing. The best way to describe it is like turning off a light switch and flipping back on?
