Alright guys heres the problem. I put my new 4'' turbo back exhaust on yesterday and now i am having a problem. The exhaust is nice, neat and cleanly put together, no leaks noticeable and the down pipe seems to be clamped to the turbo flawlessly. However, under harder acceleration and higher RPM's my motor is making this very loud (low Decible) groan/moan sound, it almost sounds like an extremely loud gas job, it almost hurts my ears. the whole truck seems to be loud i can feel the moaning sound/vibration in my feet and floor boards too. Im a little discouraged it seems like there could be so many causes for this and just wondering if anyone has ever experienced this before. I dont think it had to do with the exhaust but its extremely coincidental that it started happening the day after i installed it. Any input would be great, thanks guys!
Check the down pipe, mine was rubbing on the cylinder head and was vibrating the truck.
so I loosened up the pipe and moved it just alittle. |
Yeah I agree sounds like your exhaust is rubbing on somthing resonating through the cab.
I installed PJ's down pipe, and I was aware that the DP may rub the cylinder head a bit and made the proper adjustments to prevent the pipe from rubbing anything, but I may have missed something. The DP is a full 4", meaning it doesnt step down to 3-1/2" at all which makes the fit extra tight. I put the truck up on the lift several times and as far as I can tell the DP is clear, I'm like 95% sure the DP isnt hitting anthing, but I could be wrong.
You guys should hear this sound, it sounds like the exhaust pipe is running thru the cab its such a sound. Deep and low-toned and is effected by the RPM's. Higher RPM's the louder it is, it almost sounds like a driveline drone, but it only did it after the Exhaust install, so it must be exhaust related. |
i bet its rubbing the cab just below the turn in the down tube at the turbo, ive had two this week do the same thing , take a prybar and put between the pipe and the body of the truck and pry the body back just a bit ,also look at trans crossmember where the exjaust runs thru it , most likely up high at the bend in the down tube though
gotta be in the down tube right at the bend then where it goes down, its rubbing the body there
Yea, jake and i made the necessary adjustments to the cross-member section, it was close, so we made some adjustments just in case. We'll have to check the downpipe more closely in all areas, thanks for the input so far guys, definitely easing my mind after a stress filed weekend
Just curious, what were the customer complaints? what were they saying their issues were and were they similar to mine at all? Just curious thanks in advance
going to New Hampshire for a few days heres a last minute
thanks guys
