no one knows - Ford Powerstroke Diesel Forum
Old 01-05-2008, 11:24 PM
Unhappy no one knows
So about a month ago my truck started making a clanking pinging sound at low rpm acceleration and some times at idle. my truck only has 120k on it so it freaked me out( sounds like bottem end problems on a gasser). I took it to my diesel shop, then another, finnaly the dealer, they all told me they cant hear it and they ran it on the comp and nothing came up. Nothing against girls but even my girlfriend who knows nothing about trucks asked me what the noise is. I took it to a tire shop to get my tires rotated and asked him to drive it and listen for the noise. He said that my front gear box is trashed and that is the noise. Its not a lot to fix like $500. It just doesnt sound right I swear its something in the moter/tranny. Maybee im crazy..... ANY HELP???
Old 01-06-2008, 01:50 AM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
i would start by checking the oils in the tranny tcase front and rear diff.
if any of them are trashed they should show up in the fluids.
if yous fron diff is bad your fluid will be a silverish color. best to check that after running it a little as the metal settles after sitting.
Old 01-06-2008, 03:56 AM
This could be your TC rattling the's trucks are bad for loud TC. Just a thought.
Old 01-06-2008, 04:25 AM
ADMIN AND TECH
if it does it at idle and your not moving how would they think its the gear box ,can you give us some more info on exactly when it does it and , is it cold or hot , etc.
Old 01-06-2008, 06:01 AM
my truck does the same thing, and has been that way for about 100k or more. I've been told it is the tc as well. Doesn't hurt anything jut really loud and annoying sometimes.
Old 01-06-2008, 10:41 AM
thanks
all fluids were checked or changed about 3k ago. It is the loudest when its real cold or when i first start it. Not consistant sometimes louder then others sometimes not at all.
Old 01-06-2008, 10:44 AM
Powerstroke Techie
sounds like injector cackle
Old 01-06-2008, 08:31 PM
Read this Post in full it cost me having to pull my tranny twice and buying a torqeconvertor that I didnt need. http://www.powerstroke.org/forum/7-3...oise-idle.html It sounds exactly like mine did I thought the bottom end was coming apart but when I would climb under with it running then it sounded like it was in the tranny
Old 01-07-2008, 03:10 AM
ADMIN AND TECH
i dont think this a torque converter issue
Old 01-07-2008, 06:06 PM
If it is the flexplate would you be able to pull the cover off and wiggle the flexplate, becuase I did that and it felt solid?
