NO BOOST NEED HELP - Ford Powerstroke Diesel Forum
Old 02-28-2013, 03:39 PM
NO BOOST NEED HELP
just installed a new compresser wheel and all went well no problems what so ever got everything back together truck runs and ideals fine but DONT BUILD any boost what so over! wheel will spin free when spun by hand. ideas?
Old 02-28-2013, 04:41 PM
check all your boots, intercooler and spider boots. i had that problem a couple of times when i got my new turbo on mine. make sure that when you put them back on you take all the oil off them and use new clamps. and don't over tighten the intake plenum boots because the intake plenums are then and a normal hose clamp will collapse it.
Old 02-28-2013, 06:10 PM
you wont create boost, while idling.. nor will you, with it in "P", and revving to the moon. Gotta light-ur up on the road.
Old 02-28-2013, 06:37 PM
check your map sensor hose and plug connection. I had a dry rotten hose replaced it and its fine now.
Old 02-28-2013, 09:27 PM
+1 for MAP issue. hose or sensor.
when driving, does it sound like a loud leak? or does it just not build boost?
Old 03-01-2013, 04:28 AM
where yuo goin with this....subscribing..
Old 03-01-2013, 05:16 AM
well, i mean if you left a CAC boot undone, you would hear it under load for sure. but if the map hose or sensor were the problem, it wouldn't make any audible indication. it just wouldn't build boost
Old 03-01-2013, 05:33 AM
alright, thought you might have been on to something, with regards to my truck. Ever since i blew up the turbo, with it then rebuilt, i get a harmonic sound from 1200-1900rpm range. Bought another turbo, rebuilt it, and same thing
Old 03-01-2013, 08:12 PM
is that only under load? or in park as well?
Old 03-11-2013, 08:24 PM
Did you hook your gauge back up?
