oil leak cant find problime? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-29-2007, 02:01 PM Thread Starter
My truck is leaking oil a small ammount everyday about the size of a quater. I looked at the 2 lines on the hpop and cant quite tell if its coming from the 3rd line on the hpop. is there an easy way to tell if its leaking from the pedistal or anywhere else.
00 f-250 lariat cc 4x4
Leveling Kit
Rs 9000's
Straight Piped
Afe stage II
Black Emblims and grill
Clear corners and lamps
Isspro tripple pod guages
Helo 835's on 305/55/20 cooper zeon's
Dptuner 60 80 120 140
jwvb.
6.0 tranny cooler in progress
scpbmxer01 is offline
post #2 of 4 Old 12-29-2007, 04:34 PM
with any leak the key is to clean the area and watch/wait for the leak to come back.
Brake cleaner or engine degreaser should do it.
ViCatz is offline
post #3 of 4 Old 12-29-2007, 06:59 PM Thread Starter
i am going to clean it tomarrow and see what i can find
Leveling Kit
Rs 9000's
Straight Piped
Afe stage II
jwvb.
post #4 of 4 Old 12-29-2007, 07:57 PM
adfields's Avatar
I would just go on and change out the 3 O-rings on the hpop and see how it works from there. It's the best bet for the leak and when I tried the "watch and see" method one blew out and pumped all the oil out of my truck 80 miles from home. I went from "I think I smell oil" to a dry sump and dead truck in less then a mile. $290 tow bill and 3 little O-rings, good as new. I was told I needed special tools to pull the lines but on mine all I needed was a 9/16" and a 5/8" wrench.
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
