NEED HELP!! - Ford Powerstroke Diesel Forum
Old 12-28-2007, 07:35 AM
NEED HELP!!
i dont know whats wrong with my truck... but after the cap blew off and it ran out of fuel its not running the same.... it has a loud knocking like im running out of fuel sometimes but then i think my tranny is going out idk i got 193500 on my truck anyone know what i should do??? maybe injectors or rebuild my tranny???
Old 12-28-2007, 07:39 AM
can you hear the knocking if you are standing outside of your truck and does it sound like the motor is gana fall apart when it knocks
Old 12-28-2007, 07:43 AM
It might be that your torque convertor is goin to crap.
Old 12-28-2007, 07:49 AM
i can hear it inside the truck i sounds like its gonna die...
Old 12-28-2007, 07:57 AM
KVFD
u probably got air in the line somewheres when i ran out of fuel. did u prime the engine again? crack your fuel filter and prime the engine and make sure all the air is out of the line. or sometimes when they run out of fuel they screw injectors up but i would start with trying to bleed the lines
wehn you filled it with diesel did you just put it in the tank or fill the fuel bowl up as well? we had an older 7.3 and one of the guys ran it outa diesel and it would run so but it looked like it wasnt pumping enough fuel into the bowl, so i toped that off and it was back to normal. hope that helps just my 1 1/2 cents
Old 12-28-2007, 08:00 AM
KVFD
thats what i was trying to get at! the fuel filter bowl. do the psd have a primer on them? jw
Old 12-28-2007, 08:31 AM
yea do they have a primer??? im thinking my injectors are messed up cause when i had a problem with my fuel pump at one point i ran out of fuel almost everyday and you could hear the injectors tapping
Old 12-28-2007, 10:05 AM
PSD's self prime and purge the air as they run. So if it's running it is primed and unless you have a pin hole sucking in air it has or will purge it out. No hand pump or any thing like that on a PSD. Check your fuel pressure as it runs and see what you have. Also double check the filter and the fuel hater in the bottom of the fuel bole.
Old 12-28-2007, 03:56 PM
what do i look for when checking the hater???
