Cold starting issue is OVER FINALLY - Ford Powerstroke Diesel Forum
post #1 of 29 Old 12-27-2007, 11:43 AM Thread Starter
cblackb's Avatar
I've put glow-plugs, GPR, cleaned all wiring, batteries load tested...etc etc..everything I could think of but still she starts hard cold. Finally I switched over to 5W-40 synthetic rotella. AMAZING, I'll never go back to 15W-40. It starts on the first cycle of glow plugs, doesn't do the "rump rump rump" thing anymore (the HPX crossover line helped this problem, but didnt' cure it). Overall the truck just runs better. So if you have a extremely hard cold starting issue...go synthetic, it works.
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
post #2 of 29 Old 12-27-2007, 11:45 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Yeah I must say it was a night and day difference for me also
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 29 Old 12-27-2007, 12:08 PM
vdrive79's Avatar
I am going to run 5-40 mobil 1 on my next oil change but a little worried because Ford doesn't recomend it, it doesn't get much below the high 20's here in Eugene Oregon and don't want to screw up my warranty. Are you guys running 5-40 synthetic year round?
vdrive79 is offline
post #4 of 29 Old 12-27-2007, 12:14 PM
vitalidle's Avatar
I have yes. I switched last winter and just stuck with it through the summer months.
Auto 93,000 miles
DP Tuner F5
post #5 of 29 Old 12-27-2007, 12:19 PM Thread Starter
cblackb's Avatar
Well I just put it in, I may switch back to regular in the summer only because the synthetic is so expensive. Technically there should be no reason why you can't run the 5W-40 year round. As long as the "hot" weight of the oil is 40, and the oil is rated for heavy-duty diesel use, you should be good. The first number is the "cold" weight, meaning how well the oil flows at low temps. Here is a good article about oil:
Maintenanceworld - How to Read an Oil Can by Ray Thibault
Tinted Glass
Zoodad Mod
Foil Delete Mod
DIY/6637 Intake Mod
CCV Mod
HPX Mod
BTS Valve Body
IAH Delete
cblackb is offline
post #6 of 29 Old 12-27-2007, 06:46 PM
adfields's Avatar
I run 5w30 Rotella non synthetic hear in Alaska. if I put 15w40 in it will NOT start without a plug in 4 hours in advance. Put the cheep 5w30 Rotella and never plug the thing in till -20f, and even if I forget to plug, it will start with a little more cranking and GP cycles. It was 6f this morning and she hit on the first touch of the key, and the wifes gas motor cranked way longer then my 7.3. It's not the synthetic it's the 5 weight that makes all the cold starting difference. Glad you got it working!
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
post #7 of 29 Old 12-28-2007, 11:40 AM
I'm also switching to the 5W-40 syn. I'm planning on running it year round as I only put on 15k miles a year and don't want to dump that expensive lube as the weather starts to warm.
2000 F350 Crewcab 4x4 7.3l with AFE stage II, MBRP 4" turbo back, Turbonetics "Quick spool" turbo with .84 housing, DP Tuner chip, 80 tow,80 econo, 120 race.
D-man is offline
post #8 of 29 Old 12-28-2007, 08:11 PM
My buddy Marcel in Winnipeg Manatoba runs Amsoil 15W- 40 Heavy Duty Marine & Diesel Oil where the temps reach -40, he does NOT plug into a heater & does not have any cold start issues! He runs exactly what I run down here in central Florida! As far as "screwing" with the Ford warranty just remember this, Ford issues API specs. called for all motors just as Nissan, Chevrolet, Jaguar, and all who intend to market a vehicle here in the U.S. The Diesel API Specs submitted by Ford for their diesel will be CI-4 (pre 07) & CJ-4 for 07 newer and older!
These are federal regulations that were set in place in 1977 with the Magnonson-Moss Act!
Have a great evening guys!
bobsoil51 is offline
post #9 of 29 Old 12-28-2007, 11:10 PM
adfields's Avatar
Have ya been with olé Marcel and witnessed this -40 cold start with no plug-in first hand? Could be things work different in Canada than Alaska but hear once it gets about 0f you cant get 15w40 out of the jug and at -40f (same as -40c) it's like play-doh. If you try to pump play-doh things tend to twist right off, if they turn at all.
ANDY
The Wifes Ride:
adfields is offline
post #10 of 29 Old 12-28-2007, 11:21 PM
Cj Ford's Avatar
im running 15W40 all winter for the last 13 years in the diesel wreckers and am running it in my F250... never had a problem with it either so far
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
