99 7.3 sputter, surge while running under load. - Ford Powerstroke Diesel Forum
Old 02-23-2013, 07:52 AM
I have a 99 7.3 with 543,000 on it pulled some containers down to Florida this week. When I would get to running at highway speed sometimes I would develop for lack of better words a sputter, not a complete miss. The truck would loose some power and surge a little to. I have replaced the fuel filter and the supply pump had tank screens cleaned and reuglator spring done. Back a few months ago I replaced #2,8,3 and 5 injectors with New alliant ones. I notice when the sputter starts it surges a little at idle for a little while till it smooths out. Also I can detect the sputter while shifting when it starts. but the is no dead miss and the exhaust at tailpipe is smooth. I get no miss codes or bad injector codes. The only code I get is waste gate selenoid performance which I have had for years and exhaust backpressure valve performance P0476 , P1690. I also replaced the ebp sensor and checked tube. Can injectors fail inttermitently without coding up? I also notice it makes a crackle type noise when accellerating when it starts acting up.
Old 02-23-2013, 10:08 AM
how does it run cold? have you performed a buzz test?
what are the details as to why the fuel system was looked at?
Old 02-23-2013, 11:12 AM
Fuel pressure was low 30psi. Screens weren't that birty in tank. Buzz test always passed even before Ireplaced the 4 bad injectors. It passes all the test in scanner last week before loading.
Old 02-23-2013, 04:21 PM
prolonged low fuel pressure can definitely cause injector damage.
the device you used, were you able to see injector per/del's?
and how does it run cold?
Old 02-23-2013, 07:59 PM
It runs good cold I need a new GPR. It only acts up when warm and it quits if I cut it off after running a ways. Sure hope it's not the new injectors.
IT seems to be more noticable when I hold it steady go on a long straightaway.
Reminds me of an old 4 barrel qaudrejet when the back quads aren't right.
Old 02-23-2013, 08:43 PM
Have you done the hutch mod? Ya, screens were cleaned, but could have clogged back up again. Simple mod, and have great conclussions.
Old 02-24-2013, 09:56 AM
hmm. i agree. this does sound an awful lot like a plugged screen.
i would install a vacuum gauge in line between the tank and the pump. if you read more than 3"/hg, you have a restriction
