wastegate?
alright so ive been noticing over the last couple of days that it sounds like there is air blowing under the hood on the right side of the truck, but its only at low RPM's. it sounds like its coming from the turbo but its hard to tell from inside the truck. also im getting 17psi of boose and i used to get 22psi about a month ago. could this be the wastegate or is it something else? once i get it out of the low RPM's i dont hear it and it runs perfect.
Possible boost leak. Check all your clamps on your boots make sure they are good and tight and look for any tears on the intercooler boots.
i just went out and checked the clamps and they all seem to be fine, if i had a tear on one of the boots wouldnt it get louder at the RPM's got higher? i can hear it at low RPM's and its like it just shuts off once i rase them.
Could be your exhaust back pressure valve sticking a bit. Are you in a cold climate where you live? Yeah usually is you have a boost leak you will know with a decrease of power and you will smoke more out the tailpipe as you aren't getting good combustion.
thats what it sounds like to me too.....
the temp out here is around when ive been hearing it was about 30 so that has to be what it is because im not loosing any power it still feels fine. how can i get rid of that? just pull it apat and clean it?
another question, if i get a boost fooler can i just disconnect the waste gate? |
alright thanks i will go disconnect it now. Hey if i pull that red tube of the wastegate now will i get the over boose code? i dont have a boost fooler yet but could i just do that for now?
You might but probobly not without running a chip or tuner overboosting that is. Won't hurt a thing to defuel if it happens just a pain in the butt.
i have a chip on there but i dont know what it is it was on there when i bought the truck. i just pulled that red tube off and blocked it and where it goes on the waste gate. the truck iw warming up so i can go see if i get codes or de-fueling
