No start when it gets warm - Ford Powerstroke Diesel Forum
Old 02-20-2013, 12:49 PM
Ive been researching forum...great info, u could get lost for weeks on here reading info. Anyway I just purchased a 99 F450 from a friend who couldnt afford the maintenance. It has a bad tranny, Wow this is about to get really off topic......ADD is a MF sometimes. It has been sitting for 6 months and it fires right up. When u shut it off and try to recrank it,it just turns over and doesnt start......unless a shot ofgood old reliable ether is used. Now before u bash me cause I know u are yelling at your computer screen right now calling me an idiot. I know it is bad so just a squirt to see if it would crank. It will. After sitting several hours or next day it will crank up. Here is a rundowm of whats been done.
-Oil changed to T6 rotella 5W40 synthetic, motorcraft oil filter
-New fuel filter, not sure but old one looked a little dirty/black (which might be leaking oil down)
-Oil from HPOP suctioned out a quart at a time 3 times and added back with Prolong additive (powerstrokehelp.com)
-manufacture date 3/99 so it must be 99.5 or late 99
-tach moves with startup a little
-ICP replaced and it turns out new one was bad, because I d/c it while running likecrap and it smoothed out
-snapon scanned it and had 20 codes in it so I cleared them and havent had my buddy back over (until tomorrow) to rescan
-buzz test came back fine
-wouldnt stsy running long enough for contribution test, for some reason it wouldnt run for more than a couple of minuted and it would stop like key was turned off. It did this with old fuel filter so I changedit and thoughtit was fine until it idled for 20 minutes (ehile I added tranny fluid, yes it was almost 6 quartys low) then itwould die right after I revedit up
-After new fuel filter after I reved it it wouldidle just fine....until the next day then it wold die all over again
-unlplugged IPR and no differetn, it wouldnt start
-ICP still unplugged it will start CEL on
I will rescan it hopefully tomorrow and get duty cycles and HPOP pressures. My buddy swears its the HPOP, but it only has 140K on her and the motor was replaced 30K ago with new longblock from FORD, and new turbo, becauseit went out 5K after new motor. Looks like all old parts were bolted to block though.
Also new #3 and #7 injectors
new batteries
new water pump
new p/s pump
new hoses
new belts
all done by previous owner.
I thought I could put a tranny in her and be good to go, since it was running flawlessly before it sat. Duggummit, my wallet is spread wide open now!!
Wow thats a lot of typing.....oh yeah i took off inspection plateon front ot HPOP and i marked bolt, bumped the key andit moves. I also tried to turn it with socket, but it was to stiff for my weak self to move. I also cleaned out EGR or that pipethats in front of plate and goes over to pass side exhaust manifold.
Thanx for any advice ifu can keep up with my flight of ideas and rants.
Old 02-21-2013, 10:38 AM
Well I pulled IPR this A/M. and the orings were shot. Replaced with good used one from buddy and viola!! Shes alive!!!! Time for dieselorings.com order to renbuild IPR for a spare.
