ae injector - Ford Powerstroke Diesel Forum
Old 12-22-2007, 09:54 AM
ae injector
i have a 2000 f350 7.3 and #8 wasn't firing. the injectors were AD and i heard that #8 was an AE so i ordered an AE injector and i took the valve cover off on the passenger side and all 4 were AD. so i replaced the Ad injector with the rebuilt AE one. i started it up this morning and it sounds like its knocking at idle from the #8 cyl. i was wondering if this was caused by replafced the Ad inj with an AE
Old 12-22-2007, 09:56 AM
also after i changed the injector the check engine light came on. i don't have a scanner right now to check what the code is.
Old 12-22-2007, 09:58 AM
Desert Shield/Storm Vet
Not sure, but someone will have the answer for you
Old 12-22-2007, 10:18 AM
I think that the AE came into use in 2001 in the number 8 hole. when you installed the injector did you pull the glow plug and turn the engine over (set up to not start) first to get the oil out of the cylinder so not to hydro lock the motor.
Jay
Old 12-22-2007, 10:31 AM
Cynic
how long did you drive it after you replaced the injector?
Old 12-22-2007, 11:03 AM
yes i pulled the glow plug than cranked it over 7-8 times. i just did the injector last night. i let it idle to warm up than i bumped the idle to about 1500 for 10-15 min than this morning i let it idle and high idle for a couple of min than drove it around only about 3-4 miles. is there a huge difference in the way the ae and ad inj fires or the timing?
Old 12-22-2007, 11:19 AM
Cynic
I would take it out and drive it around to remove air in the system. Check your oil level before you leave.
Old 12-22-2007, 11:20 AM
Cynic
Someone will be in shortly to see if there was a program change between AD and AE.
Old 12-23-2007, 04:54 AM
i ended up taking the AE injector out and throwing an AD in and it runs better now but the SES light is still on. i went to advance and tried one of their cheap scanners and it wasn't able to pull any codes. the SES light is only on when its running its not on when the key is on but not running.
Old 12-23-2007, 05:57 AM
where are you located ? if we knew someone might know a good shop to help out.
Jay
