smoke on start up - Ford Powerstroke Diesel Forum
Old 12-22-2007, 08:11 AM
smoke on start up
99 7.3 Starts fine, but what sounds like rod knock and lots of white smoke. Smoke goes away after truck heats up. No dtc's are in the reader.
Old 01-09-2008, 04:51 PM
Send a message via MSN to wyoming
here's a bump. I'm having the same problem
Old 01-09-2008, 08:20 PM
Wyoming-
My problem is gone....One of the injectors was dirty.. Took it out and cleaned it all is well. Also I started using a additive to run through my tank no problems as of yet.. I also got some info about oil pressure, if it is low this could also cause this.. Good luck
