turbo clamp seal ? - Ford Powerstroke Diesel Forum
Old 02-15-2013, 09:43 AM
turbo clamp seal ?
intercooler pipes connect to turbo with a hose type clamp that has three metal square inserts that fit this connection. Is there supposed to be a seal or gasket under this? I can hear air leaking with my leak detector/compresser hooked to the intake. My 6.0 had a t clamp here, I am new to the 7.3 . thanks
Old 02-15-2013, 04:20 PM
gotta pic of the troubled connection. Cant picture what ur talk'n about, sorry.
Old 02-16-2013, 05:52 AM
Well its actually where the intake manifold clamps to the turbo. I think the o ring is supposed to seal it ?
Old 02-16-2013, 05:59 AM
turbo clamp seal ?
Yes, there is an O Ring on the turbo that suppose to seal that connection. O Ring is probably bad.
Sent from AutoGuide.com App
Old 02-16-2013, 06:07 AM
thats whatthrew me off...ur referring to the "spider" assy...
thanks, it seems the spyder housing and the compressor housing were not lining up good and flush. I removed the int. boots and cleaned them , and was able to get the housing flanges mated up better with the boots off.
Old 02-16-2013, 09:12 AM
usually on these, i have the spider boot clamps all loose, then mate the spider to the turbo, tighten up that connection, then slide the boots into position, then tighten up the boot clamps
Old 02-16-2013, 04:18 PM
yep, i think that gives more spider movement to position the flanges of both...
