X-post cracked heads, fuel cups, ??? - Ford Powerstroke Diesel Forum
Old 12-14-2007, 01:10 PM
Early '99 sipping coolant ?s
I've searched on this prob. somewhat and found possibility of cracked fuel cups? Anyone?
TIA
Old 12-16-2007, 11:05 AM
OK, I'm going to start with the fuel cup check replacement. Here's where I'm at;
Found source for new injector O-rings, but still need;
Fuel cups themselves and the tools to do this job. I look up fueling/injector parts on PSSD.com's site and it comes up with part fiche for gas models.
Who/what is OTC, which has that special tool for cup removal. Also, there is a recommended tool for removing the injectors themselves.
Dockboy had full set of cups FS, but of course they're sold...
Any direction here would be appreciated.
Techs out there with a good link for this procedure and tooling?
TIA,
jack
Old 12-16-2007, 11:07 AM
Jon
Guest
Posts: n/a
Well,
You can only get 1,2,3,4,5,6 and 7 with the heads on. The tool itself is about $550 buck just to get them out.
Old 12-16-2007, 12:05 PM
John Wood Nut Swinger
powerstrokeshop.com has the cups
Powerstrokeshop.com
The special tool to get the injectors out is a pry bar.
Jon, have you or anyone tryed rocking the engine to get the cup out like you do to install stud and HD valve springs?
Old 12-16-2007, 12:12 PM
Jon
Guest
Posts: n/a
Hmmm
no but thats a thought. Cant say i'm gonna do it with a pry bar thought. How is it you get ahold of the cup with a pry bar?
Old 12-16-2007, 03:31 PM
Pull off the outer heater/ac box and you should have room. It's only 6 bolts and a couple plugs then you can roll the box over out of the way as far as the A/C lines will reach.
Old 12-16-2007, 09:54 PM
Pry bar was for the injectors. I have no idea how to get a injector cup out.
Old 12-17-2007, 03:45 AM
Jon
Guest
Posts: n/a
Ok
thats what I thought.
Old 12-26-2007, 09:33 AM
Powerstrokeshop.com
Thanks for the link to the correct parts. Just waiting for PSSD.com to get back from vacation....Will take pics and post when I'm done. It looks like this is a common job many of us need done.
