Think I may have Fuel Problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-13-2007, 06:28 PM Thread Starter
nic2fast's Avatar
Hey guys, I have a 99 f350 with 295,000 miles on it. I read another guys post and he was having the same problem and he had low fuel pressure from a callasped filter. The problem is when I go up hills or put the truck under strain it loose power. I will go from 55 to 40 up an average size hill, even small hills, still loose some speed. I took the truck in to ford to fix a diesel leak from the drain tube and then let it sit in the yard for about two months with minimal driving and after that is when I noticed this problem. I just put a superchip on it and set it on the lowest setting (because I haven't got my gauges yet) and it did not help any. I read in that same post as earlier mentioned that there is a place to check fuel pressure at the back of the heads, does it take anything special to check the pressure on these truck. I have a tester for you average car. Need some help guys!!
nic2fast is offline
post #2 of 4 Old 12-13-2007, 06:37 PM
John Wood Nut Swinger
strokin_early_99's Avatar
There is a fitting on the back of the fuel bowl that is a #4 O ring boss fitting. You can put an adaptor in there to attach to a fuel pressure gauge you may have laying around. My first one was an oil filled 100psi hydraulic gauge. The gauge should be at least 60psi, most are 100psi. The 7.3 should have between 45-60psi.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 4 Old 12-16-2007, 02:42 PM Thread Starter
nic2fast's Avatar
when you say fuel bowl do you mean the filter housing?
99 F350 4x4 Crew Cab Duelly Flatbed
Automatic w John woods VB and HD converter
4:88 gears
Leveling kit
460,000 miles on truck 130k on motor
22.5 Peterbuilt wheels with 36" tires
Dp-tuner Chip
Gauges
4in Turbo Back Silverline Exh. into grand rock 6" mitercut stacks
Irate Diesel S366 turbo kit
Full Force diesel Stage 1 Injectors
DIY Intake
Terminator modded HPOP
Irate Diesel comp. fuel system with RR
Iron Bull Front Bumper with 12,5 winch
Reacon smoked cab lights and LED bed lights
nic2fast is offline
post #4 of 4 Old 12-16-2007, 03:40 PM
strokermann's Avatar
yep thats what he means
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
