Fuel smell and leaking - Ford Powerstroke Diesel Forum
Old 02-12-2013, 10:25 AM
Hello I have a 2000 f-250 7.3 I smell fuel and know its leaking somewhere fuel on the back of the motor. Any suggestions on where to start looking. In need of help. Thanks.
Old 02-12-2013, 09:10 PM
Most of the time it's the water drain on the fuel bowl. The o-rings leak and the fuel runs down the valley to the back of the motor.
Old 02-13-2013, 11:59 AM
okay thanks a lot I looked down in the valley of the motor and can see the fuel laying in the valley. I think that looks to be the problem. Thanks a lot in going to put that part on later tonight.
Old 02-13-2013, 12:04 PM
Re: Fuel smell and leaking
Also check your fuel line fitting to the bowl and heads. I had my drain valve leaking and after I fixed the leaking bowl it was leaking out of the line that goes into the heads.
Ford sells a nice kit for the orings to do all the lines for $25.
Or Bob over at dieselorings has a total fuel bowl rebuild kit and the orings for the heads. He is where I got the orings for my truck
Sent from my DROID BIONIC using AutoGuide.Com Free App
Old 02-17-2013, 03:50 PM
Don't overlook the simple either. I chased a leak for a while and it turned out to be the cap on the fuel bowl had cracked. Was giving a thin stream down and was really hard to see until it got really bad and coated the underside of my hood.
Old 02-17-2013, 05:22 PM
also, check the p/s fuel line where in goes thru the "P" clamp. The lines' notorious of rubbing there, creating a whole.
