My 2000 f-250 7.3 has been running great 105,000 miles. Today it cut off and check engine light came on, Then I was ab le to get it started and keep it running by pumping the gas pedal and keeping the rpm's up;.Made it to the garage, where it can be started then cuts out. Any clues feel free to point me in a direction. thanks
Also there was a clicking sound coming from somewhere under the hood, sounded like a relay but not as loud as a solenoid. |
Maybe the fuel pump relay is weak. Make sure the batteries are good and the alternator is charging.
could be the fuel pump...could be an under valve cover harness....CMP sensor....
If you could get the code it would help a lot... |
how was oil pressure start with basics and try and pull that code that should get you going also check the icp sensor
HA congrats you just answered a 3 year old thread!!
lol, 3 years old.
Check the I.P.R. That's what it sounds like.
