new B - Ford Powerstroke Diesel Forum
post #1 of 24 Old 12-11-2007, 02:54 PM Thread Starter
Arce3167's Avatar
Exclamation HELP NEW B
Hey guys, this is my first thread here. I usually hang out at the Fullsize Bronco forum but my dads 2000 7.3L Excursion has a problem. I checked for codes and none. The problem is it wont go passed 35mph, when you try to go faster it starts to shake. The rpms climb put it has no power NONE at all. You pull over and it idle really bad you rev the engine and puffs of blue smoke come out, the rpms climb slowly. You rev couple more times and it goes away, then it idle good and the rpms climb like if nothing was ever wrong. You drive away and from 0mph to 25mph its good put 30mph to 35mph it shakes and the same problem. The Excursion has a 6 inch lift, but everything is stock except that we had the muffler deleted and its straight pipe.
Arce3167 is offline
post #2 of 24 Old 12-11-2007, 02:59 PM Thread Starter
Arce3167's Avatar
sorry but if helps it has 139,000 miles, PLEASE HELP
Arce3167 is offline
post #3 of 24 Old 12-11-2007, 03:03 PM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
Bump. I know blue smoke is oil burning. thats all i got. someone will help just be persistent
lifewitlooie is offline
post #4 of 24 Old 12-12-2007, 06:56 AM Thread Starter
Arce3167's Avatar
How do you Bumb?
Arce3167 is offline
post #5 of 24 Old 12-12-2007, 10:56 AM
adfields's Avatar
Originally Posted by Arce3167 View Post
How do you Bumb?
You bump just like you did, post on it.
Guys often use this smilie for fun.
Now to your trouble. I am at some what of a loss hear but I have read that the trans has a "safe" mode in the computer thats acts like this. It prevents you from driving over 30mph, shifts very hard and is to force you in for service before bad damage. It is also said to flash the O/D off light alerting you that you have codes in the trans. Not sure at all if this is your trouble but it's my first thought.
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
post #6 of 24 Old 12-13-2007, 07:34 PM Thread Starter
Arce3167's Avatar
it stutters like a gasser does when you have a spark plug miss and lots of blue smoke comes out the tail pipe, changed the fuel filter but no change. Counld the ICP sensor be causing this
Arce3167 is offline
post #7 of 24 Old 12-13-2007, 07:44 PM
nic0084's Avatar
How do you Bumb?
you may have figured it out, but bumping, which is just another post to your thread, BUMPS you to the top of the thread list on the homepage so people will see your thread and read it.
hope someone can help.....
BUMP
97 F350 7.3 Off-Road Build Locked on 42's
08 2500 Cummins
nic0084 is offline
post #8 of 24 Old 12-13-2007, 07:46 PM Thread Starter
Arce3167's Avatar
Thanks guys for you help
Arce3167 is offline
post #9 of 24 Old 12-13-2007, 07:59 PM
Ole White
bigwhite7.3stroker's Avatar
Bump
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #10 of 24 Old 12-14-2007, 05:58 AM Thread Starter
Arce3167's Avatar
I checked the ICP sensor cause in another thread some said it had oil in the sensor and the connector did too. My sensor has oil too, i cleaned it but no change. Should i replace it? Or would something else be causing this. Its like fuel cuts out and the truck losses all power
Arce3167 is offline
