Bogs down and whole truck shakes near 30 when accelerating
my truck just started bogging down when i give it full to half throttle. During the bogging the whole truck vibrates. I can drive it a normal by steadily giving it gas but it will not pick up speed at half throttle once i reach 30mph or 2000 rpm. Also i noticed when i let go of the throttle i can hear air blowing back out of the air filter like a blowoff valve, which we dont have. The truck idles good and can rev it above 2000rpm with no problem parked. Anyone have any input? I recently did the ccv mod without the canister, just dumping in towards my rear. Can that be the problem? Also my truck has been parked since OCT and ran normal then, Just started back up yesterday and noticed the problem. Oil is clean and not low.
remove the air cleaner boot and have a look at the compressor wheel and housing.
well I can't check it now, last night while driving it, the motor just died down and won't start anymore. The ICP harness has some oil on it, but will it make my motor die while driving?
it could. disconnecting it would make the pcm run the engine off of calculated parameters. you can try that.
but start by checking for codes with a device capable of reading manufacturer specific codes could even be a bad cmp sensor among many other possibilities |
Still wont start unplugged, cps sensor was replaced with blk one 6 months ago, but my old one was still working. I will put the old one back in.
check the codes. record. clear them. crank engine several times. then check again
Ok it's working now, code was cps sensor which i changed out 6 months ago, and p2301. Which i found out was the inertia switch. Truck runs like a champ now
My truck has been doing the same thing! And when it down shifts it runs fine. What exactly do I need to fix?
