hard start cool temp (No Fault Codes)
Hello, everyone first post for me, proud to be a member of such a community.
I started having problems on cool mornings below 45 degrees. Truck would crank and crank and wouldn't start. After turning key on and off several times truck would start and produce a large cloud of white smoke. The truck is not showing any fault codes. Any ideas. |
Check the Glow Plug Relay (located on the top of the engine pass. side) Check for power coming out of the Relay when the key is first turned to the on position. There are 4 terminals on the relay 2 small and 2 big, you need to check the 1 big one with the 2 wires on the right side of the relay when standing in front of the truck. (try to check this while the wait to start light is still on) if it has power you may have bad glow plugs, no power check the other big terminal (left side of the relay), if it has power relay is bad. Oh and
I just replaced my glow plug relay today. I could hear the relay click but it would not start. I put clamp ends on my fluke meter and clipped it on the lug closest to the center of the engine and of course a ground. Then I threw the meter up on the window and watched while I cycled the key. NOTHING. Dang it!!!! I tried it again and still nothing. I smacked the relay with the key in the on position and still nothing. I verified power was present at the lug closest to the fender. Then did it all again and still nothing.
I replaced the relay with a new one and it fired right up. Look here at a good write up: 7.3 glow plug system diagnosis Keep Strokin' |
Thank you Viper5 and strokin early 99! I will try your recommendations over the weekend and post results.
Thanks, 00' Stroker
Glow plugs. The problem was glow plugs. thanks for the assistance
I learned the hard way on my 01 to let the glow plugs cycle even when it was warm out
waiting for the light to go off even if its only going to be on a few seconds can save the relays I replaced the relay every faal till I figured this out DUH HUH.. |
