lost starter bolt on 02 - Ford Powerstroke Diesel Forum
Old 12-09-2007, 07:11 AM
for some reason, my factory starter on my 02 decided to start wiggling loose, well i got in it the other morning to start and the thing sounded like the starter was going out. (first thoughts where great 200 bucks.) after some investigation, i crawled up uderneath and found the starter loose. the top bolt had fallen out and the bottom one was loose. i tightened the bottom one up but was curious if someone could give me an idea if the top bolt is the same length as the bottom bolt?
Old 12-09-2007, 07:44 AM
Powerstroke Techie
As best as I can remember they are identical and metric on mine .
Old 12-09-2007, 08:06 AM
Jon
Guest
Posts: n/a
Yeah
they are the same, I had mine come loose and have seen about a dozen others. Fairly common.
Old 12-09-2007, 08:13 AM
My sis in law had that happen yesterday on her 03 7.3
Old 12-09-2007, 12:12 PM
My 95 has 3 and all the same. So the newer ones just have 2?
Old 12-09-2007, 06:01 PM
well, went to advanced auto parts and bought a couple bolts....
part number 980-530
M10-1,50 x 30mm
used a 15 mm socket.
tad bit shorter than the factory bolt but still worked.
Old 12-12-2007, 02:55 AM
A Buddy of mine had the same problem 03 is this a new problem chewed fly wheel up .
Old 12-12-2007, 11:34 AM
I would use some LockTight on them.
