EBP Tube - Ford Powerstroke Diesel Forum
Old 02-01-2013, 07:31 PM
EBP Tube
I want to clean the Exhaust Back Pressure tube but I am afraid I will break it off at the manifold. Does anyone know if I can clean it without removing it? I was thinking of taking the sensor off and cleaning the tube in place. With 480K plus miles on the truck I am not confidant I will not break it.
Old 02-13-2013, 07:15 AM
Send a message via AIM to rufushusky
According to this you can just use a snake to clean it out... just remove the sensor...
EBP Tube-ebp-tube-sensor-cleaning-pg1.jpg   EBP Tube-ebp-tube-sensor-cleaning-pg2.jpg   EBP Tube-ebp-tube-sensor-cleaning-pg3.jpg
Old 04-22-2013, 03:51 PM
i am unable to find that snake tool anywhere! bummer....
Old 04-22-2013, 03:56 PM
Do you have a harbor freight near by? They have one that will work for 5-10 bucks.
Old 04-23-2013, 02:36 PM
I soaked my with WD40 because I was afraid of it breaking also. It was broken in half anyway. It looked like it's never been off. Nut still broke loose with no problems after about a 20 min soak tho. Had to get a new 1 at the dealer for about $75. Here is what it looked like. [IMG][/IMG]
Old 04-23-2013, 03:48 PM
yes, i'm gonna head there. i saw a cheesy looking spider snake for a sink at lowe's home improvement, looks like that'll work also. we'll see. thanks.
Old 04-24-2013, 10:45 PM
Autozone actually carries these or they can get them the next day. Plus they are stainless. Just so you know, autozone calls them an EGR line. I don't know why since our trucks don't have an EGR, at least mine doesn't. I think I paid $35.00.
Old 04-24-2013, 11:24 PM
A piece of speedometer or choke cable will work. I used a piece of speedo cable in a cordless drill, worked like a charm.
Old 04-26-2013, 05:50 PM
Thanks for that tip hucorey! I just tried to clean mine - the wire I used went right throught the side of the tube. It looked pretty bad anyway so... off to Autozone tomorrow.
Old 04-26-2013, 05:58 PM
we ended up using the flex tube cleaner from a gun cleaning kit. it worked out great! my EBPS/tube was plugged solid. thanks for the tips!
