Missing coolant
I changed the oil today and checked the coolant and it was low I have filled it a couple times and after while the level will go down to the little ford logo on the tank. Every time it goes down to this level but the thing is I can't find a single wet spot where it has been leaking and I don't have coolant in the oil so I know its not a head. I does not overheat even in the summer so I really havent worried about it but just curious to know if this is a common thing or what's going on.
Missing coolant
Look around the thermostat housing, it likes to leak there, go down the engine and dry on the bottom rad hose
Sent from AutoGuide.com App |
Re: Missing coolant
Will do thank you
Missing coolant
Re: Missing coolant
Will do I'll check tomorrow but it won't be till this weekend I will be able to check good. Will I be able to tell with the motor cold or does it need to be up to operating temp
Missing coolant
Usually the leaks show up the best while warm, but typically you will see it all the time
Re: Missing coolant
Alright I found where the coolant is going. Its the t stat housing it is crusty underneath where the radiator hose goes in and is dripping onto the radiator hose at the bottom of the radiator. Should I replace just the gasket or do you think I should replace the t stat since I have it apart?
Missing coolant
Missing coolant
I had a similar issue today. Noticed a leak under the truck. Ended up being where the upper radiator hose connects to the tstat. The factory clamp had weakened and was letting coolant out. Replaced it with an old fashioned hose clamp and the problem was fixed.
Missing coolant
