7.3L runs rough,then stalls - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-26-2007, 03:35 PM Thread Starter
Exclamation 7.3L runs rough,then stalls
Hi, I have a 1995 F250 powerstroke with dual fuel tanks. The problem I have been having is when I drive down the road with the fuel tank slector on the front tank, It somtimes will start to run rough, so rough infact that the steering wheel will start to shake, and it loses all power. I can pull over on the side of the road and it shakes like it is only running on 6 cylinders or less, then I swicth the fuel tank selector to the rear tank and after 6 seconds it runs just fine. The problem is intermitent because somtimes I can drive 40 miles on the front tank and have no problems, other times I can only drive 2 miles and it starts, but as soon as I switch tanks it goes away. Now, I replaced the tank selector assembly and also made sure that the pickup and return lines were not plugging up in the front tank. The front tank is plastic, so there can't be rust in there, And I never have any leaks anywhere. Fuel filter has 5,000 miles on it, and also it does'nt seem to matter if the tank is full or not. I hope someone can help, cause it is driving me crazy. Thank you.
7.3 max is offline
post #2 of 3 Old 11-26-2007, 03:47 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Hmm maybe sucking air
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 3 Old 11-27-2007, 01:50 PM Thread Starter
Thats what I thought, but if it was sucking air somewhere it should cause it to run bad all the time, and not just once every so often, shoud'nt it?
7.3 max is offline
