glow plug relay confusion? - Ford Powerstroke Diesel Forum
Old 01-24-2013, 10:20 AM
Send a message via AIM to mdkallam130
i bought a glow plug relay for my 2002 f250 with a 7.3 from autozone. This particular relay has two red wires coming off of it into a plugin connector.
My question is where does the connector go and what does it do?
Old 01-24-2013, 10:23 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
Never seen that before?????
Old 01-24-2013, 10:25 AM
Me either. Its got me puzzled and concerned that it may be the wrong one.
Old 01-24-2013, 10:39 AM
Buy from FORD!!
Old 01-24-2013, 12:20 PM
The FORD one kinda sucks too though
If you want to get a bullet proof relay go with Stancore ->
Welcome to guzzle's Stancor GPR replacement Mod Web Page
All relays are pretty simple... What you have is Not, specifically, made for your truck but could easily be used. The plug has the two Coil wires in it. Just take those two small wires (and the plug) off and connect your two small wires to those connections (doesn't matter which way they go) and your two Large wires to the two Large terminals.
Old 01-24-2013, 12:23 PM
some of them have the connector if you buy elcheapo one customer bought did. I (this is what I would do if I was you) double check part #'s and just take it off...just be advised elcheapo wont last long...
Old 01-24-2013, 06:26 PM
i believe those are the dorman ones. it's the "right" one. don't worry
Old 01-25-2013, 12:33 PM
Might be a universal one that fits the older OBS setups. My 95 had a plug molded into the relay vs the two small studs. Just remove the pigtail and put your small wires on the small studs and large wires on the large studs and you should be fine.
Old 01-25-2013, 06:47 PM
Originally Posted by Dorman Diesel View Post
That is not a Dorman Unit.
i stand corrected! haha
