Oil Leak - Ford Powerstroke Diesel Forum
Old 01-24-2013, 08:08 AM
Oil Leak
Well to start off with i have read and been doing research for multiple months on my oil leak. I cant seem to find one just like it. Ive checked the HPOP lines, turbo pedestal as best as i can with out taking it off. The valley is only wet/puddling tward the back of the valley. Under the truck it is dripping around where the starter is, where the little drain deal is, and on the other side of the motor as well. About two months ago i found out that the valve on back of the water/fuel separator was leaking. So i fixed that and everything stopped leaking. Thought i fixed my problem. The other day i noticed the truck was low on oil so i topped it off. As soon as i topped it off it started leaking again.
Now keep in mind i am kinda anal about leaks and what not and when im saying its leaking its about the size of a quarter over night. I just dont understand why it would leak when its full of oil and not when its low.
P.S. No i didnt spill any when i filled it up.
Its a 2000 F250, 7.3 4x4 just under 200k.
Thanks for your time.
Old 01-25-2013, 03:09 PM
Oil Leak
Any thoughts?......
