Smoke - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-23-2013, 08:06 AM Thread Starter
Smoke
I have a 95 F-250 that I need help diagnosing a problem with. I am trying to figure out what the deal is with the smoke I'm blowing. It's cold in Maryland right now and when I start the truck in the morning a huge cloud of white smoke rolls out of the exhaust after about five minutes it calms down to what I consider normal. Also, when I stomp the throttle it blows grey before black (obviously burning oil).
There are a number of things that I think might be an issue or possibly a combination of things:
1. Blown head gasket
2. Bad crank bearing
3. Cracked injector sleeve
4. Clogged injector
Once the truck is up to heat, it does blows very little white smoke but, hardly any. Please help me figure this out.
AWF2 is offline
post #2 of 11 Old 01-23-2013, 08:11 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Start up smoke is normal, Mine pours smoke on cold start up's
2000-7.3L is offline
post #3 of 11 Old 01-23-2013, 08:17 AM Thread Starter
I figured it would do this when it got cold, but it's really coming out thick and kind of rough to start at first plus - expectedly - it runs rough till its warm.
AWF2 is offline
post #4 of 11 Old 01-23-2013, 08:19 AM
2000-7.3L's Avatar
How long does it run rough? 5 mins after start up or 30 min when the truck itself is warm?
post #5 of 11 Old 01-23-2013, 01:08 PM Thread Starter
It runs rough for about 5 to 10 minutes but when the truck gets warm it runs solid. But when it's running rough its not holding a steady rpm and almost sounds like a cylinder is not firing right.
AWF2 is offline
post #6 of 11 Old 01-23-2013, 01:09 PM Thread Starter
I've read that it might even be a glow plug not getting hot enough to fire right
AWF2 is offline
post #7 of 11 Old 01-23-2013, 07:00 PM
Powerstroke Techie
Quoted: 344 Post(s)
amp test the glow plug circuit
the richest ones are not those who have the most, but those who need the least
kaya is offline
post #8 of 11 Old 01-23-2013, 07:27 PM
Quoted: 4 Post(s)
Sounds like a bad injector or two. Mine wouldn't start without block heater last year, when it got below 40. I put four injectors in it in sept.
You should be able to test them and find the bad ones or get someone with a break out box to check it cold.
mcgoo422000 is offline
post #9 of 11 Old 01-24-2013, 03:23 PM Thread Starter
I don't know what happened but it hasn't had the issue for three days now. The temp is the same. I wonder if I just had water in the fuel or somethng sticking.
AWF2 is offline
post #10 of 11 Old 01-26-2013, 12:36 AM
700xxmaniac's Avatar
Smoke
Sounds like injectors to me, what kind of oil are you running, but the grey smoke is not oil it's diesel that's half burnt, if u had enough oil burning to make grey smoke you'd would have a run away almost instantly.
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
