Overly hot water pump, gauge normal? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-19-2013, 11:02 AM Thread Starter
Ok, got a question. Just replaced my water pump (again), t-stat and fan clutch. Run the truck and temp gauge stays in the middle of normal range but the water pump and hpop reservoir are hot as a firecracker. It seems to me to be way to hot. I did pull the plug on the reservoir to check the oil temp w/ a meat thermometer and it only read 160. Just feels to me that the pump and reservoir are way hotter than that. Any ideas on what to look at for a possible cause? Or am I being paranoid and they are supposed to be where you can't even hold a finger on them? Just don't remember them ever being that hot. Thanks!
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
post #2 of 3 Old 01-19-2013, 11:45 AM
jesilvas's Avatar
Quoted: 3 Post(s)
The dash gauge isn't accurate.
Also, you're finger is ~98.6*F. 160*F is 70*F higher than your finger. So it's gonna feel hot.
You can read the truck's data and see what the temp sensors are showing if you're worried.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 3 Old 01-19-2013, 11:53 AM Thread Starter
Thanks for the reply! I'll have to see if I can get someone to scan it for me and check the temps. They just feel hot like a stove burner or something. Hotter than I would think 160 would feel. But I'm no human thermometer!
01 F350 CCSB 4x4
Leveled
AIS
Va7.3L is offline
