possible pcm prob?
truck dies randomly,took it to mech.8,and 3 injector dieing and icp codes.replaced them all.still doing the same stuff.maybe pcm?shifts erratic once in a while also.was thinking maybe all this is linked?
Replace the CPS
Thats been replaced too,along with alot of other things.the mech did say he got a pcm code once too.This has got me stumped.
what were the code(s)?
does the truck start up fine immediately after it stalls? you need to have a monitor on it when the problem occurs. otherwise, you're just shooting in the dark. as i'm sure you've realized |
Icp code,and he said he got a pcm code once.and #3#8 injectors were shot.
need a little more description. the exact codes please, with the numbers. does it only stall when hot? or cold as well? again, does it fire up fine immediately after the stall?
Yea,Don't have the codes.mech did it.when it dies its slow to restart.its like its run outta fuel.I'm done with it,its going to the ford shop monday.Or the fire pit.if it stops on me on the way to the dealership.
Well it seems that there is a blockage in the fuel tank.Ford dealer says there is a fuel restriction.dropping the tank today.Find out tomorrow.
not sure how that would cause an icp code..
No,It had other probs too.The icp was full of oil.and I changed it out before I took it to the ford shop.
