Constant belt squeel, shredding belts, need help please! - Ford Powerstroke Diesel Forum
Old 01-12-2013, 03:02 PM
i have a 2000 7.3 f250, when getting it on the road (august) the belt was squeeling so we replaced idler bearings, cleaned pulleys and replaced belt, within 3 days of getting it on the road it shredded a strand off the belt and left pieces scattered about the engine bay. got the belt replaced, within another couple days it did the same thing. so i left the belt like that, with a strand ripped off all the way around. it didnt shred it any further, but it was constantly squeeling, so i got some lithium grease spray (i believe it was) and sprayed my belt, as soon as i sprayed the side with the tread or whatever its actually called the squeeling stopped. so for a while now ive just been spraying it to shut it up. put my original belt back on today because it wasnt shredded so i wanted to see if it made a difference. this one actually squeels worse. so my question is why am i constantly shredding belts? ill keep an eye on this belt to see if it shreds, but spraying it only shuts it up for a few seconds...
thanks guys
Old 01-13-2013, 09:48 AM
Old 01-13-2013, 11:53 AM
I'll bet its a misaligned pulley. Look at the front of the motor from the side and see if you can see a pulley that is a bit forward or back from the rest. My power steering pulley was pushed in just enough to make that squealing so I pulled it out about 1/8"
Old 01-13-2013, 11:59 AM
Alright thanks.
Old 01-16-2013, 05:22 PM
I just went through the exact thing on an 01. Couldnt find anything loose or binding.Tensionor was tight and not loose but after closer look it was tilted less then an 1/8'' but was enough to cause it to ride up on AC pulley and shred the fornt of the belt. And it had an annoying squeel. Replaced whole tensionor for $65 all is good now
Old 01-16-2013, 05:30 PM
thanks for the reply man. I'll look into it on the weekend. Was there anyway to adjust the tensioner back or does it need to be replaced
Old 01-16-2013, 05:50 PM
u just replace.2 bolts holding it in real easy. Take it off and look at the area where the 2 pieces meet and look for a small gap on one or the other.it doesnt take much to throw it off.
Old 01-16-2013, 05:57 PM
Awesome thanks for the help! Appreciate it
Old 02-19-2013, 02:00 PM
just changed my tensioner yesterday, same problem..replaced the idler pulley too. 140.00 for the tensioner, idler, and belt. Good as new
Old 02-20-2013, 11:17 AM
Had the same problem its the Tensioner. Did the same thing as drummondracing did its good as new!!
