Firing order. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-08-2007, 04:05 PM Thread Starter
alexanderhook's Avatar
Send a message via MSN to alexanderhook
Firing order.
I can't find a Haynes or a Chilton manual for my 1995 F350 7.3L stroke. Anyone know where I can get the firing order? Or anyone have that info? We wanna crank the pistons over and make sure they are properly working in the right order.
<Alehkzanduhr>
alexanderhook is offline
post #2 of 5 Old 11-08-2007, 04:07 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Cylinder numbers are assigned 1,3,5,7 on the left or passenger side from front of truck to back, and 2,4,6,8 on the driver's side, front to back. Firing order is 1,2,7,3,4,5,6,8.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 5 Old 11-08-2007, 04:52 PM Thread Starter
Thank you so much man! That helps a lot! Thanks again.
<Alehkzanduhr>
post #4 of 5 Old 11-08-2007, 04:53 PM
vitalidle's Avatar
You bet! Good luck
Auto 93,000 miles
DP Tuner F5
post #5 of 5 Old 11-18-2007, 04:31 PM Thread Starter
Does anyone know where I can get the timing marks for the engine?
<Alehkzanduhr>
