No start 7.3 - Ford Powerstroke Diesel Forum
Old 01-04-2013, 06:14 PM
No start 7.3
I was driving my truck and the SES light came on and truck lost power and in a couple of miles picked back up and started running fine. when i got home SES light was on again i shut truck off and waited till next day truck started fine but ran rough with SES light on i had a low ICP sensor code i replaced ICP sensor it was leaking oil and plug was soaked cleaned the plug and put back on still had the SES light and ran rough. I ran out of time and had to let it sit for a few days and now when i try to start it only cranks over it acts like at times it want to hit but doesnt it is smoking from the exhaust . i am still getting the code for ICP pressure being low and also getting a IDM code . in the past 3 months i have done the following work on the truck new batteries new injectors and orings new motorcraft glow plugs and under valve cover harness I have a auto enginuity program i am new to it so any help you could give with the truck or scan tool will bw appreciated
Old 01-04-2013, 06:28 PM
Need to monitor icp and ipr whole cranking
I made my Samsung SGH-I997 send this.
Old 01-04-2013, 06:34 PM
what part of auto enginuity do i go to i found the icp in the list the icp pressure is about 2200 when cranking i do have fuel in the fuel bowl also
Old 01-04-2013, 06:45 PM
2200 seems really high cranking
Does the fuel pump run?
