#7 GP circuit Failure - Ford Powerstroke Diesel Forum
Old 01-01-2013, 09:09 PM
I have a 01 California Powerstroke. I have a service engine light with code p0677 which when I researched on here found to be a number 7 glow plug circuit failure. I want to clear the water a bit before I throw parts at it. Could it be as simple as the number 7 glow plug has failed or a problem in the California exclusive glow plug controller module?
Also, there appears to be a glow plug relay next to the controller module. It does not power the glow plugs but rather some sort of intake air heater. I used a multimeter and tested it similarly to testing a gp relay but had no volts on the intake air heater side. Could this be controlled by the module as well?
Old 01-04-2013, 04:50 PM
No one has any ideas?
Old 01-04-2013, 06:33 PM
That is the air intake heater. Pcm controlled. I wouldn't worry about it.
The bad gp could be a bad gp or a bad uvch. You'll need to ohm the harness and plug out.
There is a sticky thread on how to do so
I made my Samsung SGH-I997 send this.
