truck wont start, HPOP maybe?
Truck is a 2001
Bowl fills with fuel all fuses checked batteries are brand new new fuel filter oil level in HPOP is good no leaks from the HPOP When ignition is on the injectors dont make a sound I can crank the motor but there is no pop what do you guys think? I have been on this forum for the past 6 hours and havent found a solution |
check the uvch or under valve cover harnesses.
make sure they are all plugged in. and no clips are broken. |
everything is plugged in.
To give a better understanding of what happened this is how the problem started came home from a 800 mile road trip and the truck sat in the driveway over the weekend. Started it up in the morning and it idled for about 3-4 min and started sputtering then died. cranked it and it would start and die and i could get it to run with my foot on the gas then after only a couple seconds of running it, it died for good. seemed like it just lost fuel |
Tap the IDM and see if it starts.
you need to start by checking codes. if it's not starting, you'll almost certainly have some codes stored. that will send you on the path to correcting the problem. instead of firing blindly. check them and report back with your findings
