Need to re flash Computer after IDM Install? - Ford Powerstroke Diesel Forum
Old 12-21-2012, 04:27 PM
So it looks like My IDM is out in my 2002 f250 and I plan on doing it myself... I've been told I need to re flash the computer after install.... Do you need to re flash it or can you just install and be on your way???
Old 12-21-2012, 07:30 PM
well, the idm needs to sync to the pcm. so that should make a reflash necessary. but i have installed new idn's without flashing. had no issues
are you using an alliant power unit?
how did you deduce the idm as the problem?
Old 12-21-2012, 07:41 PM
Took it in to one of my trusted mechanics and they told me thats one of the issues that started... I've seen the IDMs posted on diesel sites for about $240.... Better than the $915 ford wants
Old 12-22-2012, 09:00 PM
Is there a way I can get a new IDM and just plug it in without taking the old one out to see if this fixes it? I've read that someplace.......
Old 12-22-2012, 10:57 PM
of course. just disconnect the old one and connect the new one loosely, without removing the old one
Old 12-24-2012, 03:58 PM
IDM's are plug and play. no flashing required.
however it is waaaay more likely that your trusted mechanic did not remove your valve covers to check the 2 UVCH plugs.
do that along with the $0.50 mod and see if that does not get your truck running again.
