help testing vss wiring - Ford Powerstroke Diesel Forum
Old 12-12-2012, 08:41 AM
I have searched for awile and cannot find where the vss wires run after the harness connection at the drivers wheel weel. I have connection from sensor to fender weel connection. Now trying to test from there to pcm but no connection. I think the wires go threw something else first like the speedo cluster or the abs module. Pleae help if you know where they run.
Old 12-12-2012, 09:41 AM
look in this pdf for the wiring diagram.
SM
Old 12-12-2012, 10:15 AM
that would be what i have been looking for. thanks
Old 12-12-2012, 03:20 PM
glad I could help out.
SM
Old 12-13-2012, 06:47 AM
hey where did you pull this pdf from. I am still tracing wites and it would be nice to have a place of refference. Now I am trying to find what wire the vss signal wire leaves the speedo cluster or even if it does. Cant find where to test the vss+ wire from the pcm to where?
Old 12-13-2012, 07:50 AM
sent you a pm.
SM
Old 12-13-2012, 08:05 AM
thanks email sent
