What one to unplug ebpv or ebps ? - Ford Powerstroke Diesel Forum
Old 12-02-2012, 06:35 AM
my truck was hissing really bad and would take forever to warm up to drive..
I unhooked the ebps and everything seems to be good, no more hissing..
but I'm told not to unhook the ebps and to unhook the ebpv ??
could someone explain
the steel hose coming from under the ebps has a big hole and is rotted out and to cold to do the repair " as seen in the 3rd photo " ... will it hurt anything to leave it be till summer when the weather is warm ? I just don't want to have any problems there...
should I leave the ebps unhooked?
should I plug it back in and unhook the ebpv ?
the van is a 1999 e450 7.3 16 foot
photo below is the van and the thing I unhooked. also a photo of the big hole in the steel line
What one to unplug ebpv or ebps ?-ricksbigtruck.jpg   What one to unplug ebpv or ebps ?-unplug.jpg   What one to unplug ebpv or ebps ?-img_20121201_165456.jpg
Old 12-02-2012, 06:48 AM
and thank you for all the help
Old 12-02-2012, 07:08 AM
Unplug the ebpv. You're probly gonna want to get that hole fixed, its definitely not helping performance
Sent from my DROID BIONIC against my will
Old 12-02-2012, 07:14 AM
thanks but I'm not sure what the benefit's are by unhooking the ebpv, when I have unhooked the ebps and seems to have fixed the big air sound... could someone explain?
and when I get around to replacing the steel line under the ebps do I have to remove the rad? I cant even see how to unhook that steel line because the rad is in the way...
Old 12-02-2012, 08:19 AM
ok, so I think I took the EBPV plug out, took a photo to show just to make sure... had to take the turbo tube thing off just to get to it....
please look and let me know....
Old 12-02-2012, 08:48 AM
The sensor measures backpressure and outputs info to the PCM. The ebpv just opens and closes the flap. I know it's not too bad on the trucks, no clue what it's like on the van, I can imagine it might be kinda squished in there.
Old 12-02-2012, 09:02 AM
that sure looks like the EBPV plug to me.
under the turbo on the side facing the front bumper. kinda a pain to get to but if you go at it from your right (as your facing the truck) you should need to remove nothing to get to it.
then again in a van body you don't exactly have the room that the rest of us have.
as far as the tube.... you don't HAVE TO replace now however you don't want to ignore it forever.
most people drive around with that tube plugged for years so if yours is the opposite and is always leaking then I see no serious harm. But for the sake of doing it order the part now and when its warm enough out for you to be willing to do it then put the new one on.
if you are like me then it will eat at you that you bought a part and have yet to install it. that way you know you will not forget to do the job when its warm out.
Old 12-02-2012, 09:07 AM
well EBPV plug is off, that boot to the turbo was hard to get back on but got it on...
also plugged the EBPs back in as suggested and going to take it for a run...
will not know for sure in till its cold again
Old 12-04-2012, 07:42 PM
how big is the hole in the tube?
That tube is basically your boost pressure from your turbo. If the hole in it is big then your turbo boost is just leaking out and you basically have no turbo helping your motor.
unplugging your EPS basically told your computer there is 0 boost pressure and then your truck did all it could to boost the turbo and you finally for once felt some boost tho it was mostly leaking out. replace the line and you will truly feel the turbo on your rig.
for now just unplug your EBPV and let her buck... but you will WANT to replace that tube.. you wont believe the power loss you are dealing with.. that little bit you felt before was nothing.
Old 12-04-2012, 09:29 PM
well, it's actually not boost. that would be the pressure side. it's the exhaust that feeds the turbo that would be leaking. similar to any exhaust leak at the manifolds or up pipes.
the ebp sensor is actually much more critical than has been explained. the ebps is an input for the pcm, used to determine fuel trim. if the pcm is reading lower backpressure because of the leak, it will defuel. replace the tube and have a look at the sensor. if it's plugged up, replace the sensor as well. i guarantee you'll feel a difference
