Fuel bowl heater is all bojangled! A little help? - Ford Powerstroke Diesel Forum
Old 11-29-2012, 07:03 AM
spool up that turbo!!
So last night driving home minding my own business the truck dies with no wait to start light and crank but no fire so i check number 30 and it's blown then I swap out number 30 20 amp fuse for my door lock 20 amp fuse and unplug my heater truck fires moves ten feet and blows the fuse again
Am I missing something?
Sent from my iPhone using AutoGuide.com App
Old 11-29-2012, 08:42 AM
Bump! If I just replace the heater will everything be fine?
Old 11-29-2012, 08:56 AM
If you unplugged the heater, then replacing it will not change anything.
Are you sure you unplugged the heater?
Old 11-29-2012, 08:58 AM
Pretty sure I did it was dark and I was a little angry that my truck died so I will double check this afternoon when I get home
Old 11-29-2012, 09:06 AM
If it IS unplugged, trace back the wires and see it it could be chafed as it passes over the valvecover (or any other place that look likely). Roll the bundle over or use a mirror and strong light.
Also, let's get a 30A back in there (without the heater I'm sure 20's enough, but, just because )
Old 11-29-2012, 10:06 AM
The book calls for a 20 amp though
Old 11-29-2012, 10:07 AM
Ill do some more digging when I get home
Old 11-29-2012, 12:54 PM
Oh sorry I though it was a 30A in position #30 (maybe I'm confusing the number with the rating)
Certainly NEVER put a 30A where a 20A belongs!
Old 11-29-2012, 02:04 PM
Exactly I've played that game before when I was younger no good haha
Old 11-29-2012, 02:41 PM
I did unplugg the heater last night but replaced the fuse again and it seems to be fine so far I don't want this thing to leave me stranded again
