Replaced gpr and truck died! Need help!!! - Ford Powerstroke Diesel Forum
Old 11-24-2012, 01:31 PM
So my truck was having some issues starting up in the cold, so I ordered a new gpr and put it in tonight. The truck has been sitting since Wednesday (today Saturday) I put it in let them cycle and it started up like it would if it were warm no smoke nothing let it idle for about 3-4 minute when it died. Like I shut the truck off. The battery light came on OD off light came on cel came on and the glow plug light came on. I shut the key down and went to crank it over, the same lights came on and it will crank and crank and crank but nothing....any ideas guy???
Old 11-24-2012, 04:21 PM
Just went to start it again and same thing...all the lights on the dash coming on and now the relays are clicking under ther dash?
Old 11-24-2012, 05:40 PM
Anyone? I need this thing running by tomorrow! Do you think cps? Poor battery connections? Would bad connections cause the truck to die?
Old 11-24-2012, 07:28 PM
Just double check everything you took off and even things you thought to take off. And then recheck them. And if you have a spare cps laying around just throw it in there. It only takes 2 minutes to switch. Good luck.
Sent from my iPhone using AutoGuide.com App
Old 11-24-2012, 07:34 PM
My drivers side battery ground was loose and caused the same thing. I hadnt touched the batteries in over a year and didnt think it was the problem, but over time it loosened up enough.
Old 11-25-2012, 05:05 AM
Will clean the connections today and grease them. Will a napa cps do or should I go to ford if that doesn't work?
Old 11-25-2012, 07:30 AM
Not the batteries, I cleaned the terminals. There's no dealers near me open on Sundays so I am going to advanced just to see if a new cps will start it. If it does ill buy oem tomorrow. Will swapping in the new gpr have anything to do with the truck not starting? Should I swap the old one back in?
Old 11-25-2012, 07:34 AM
Did you make sure to mark each wire to the correct location when you removed them from the old GPR? And did you make sure that all the wires went back to the correct terminals on the new GPR? This picture may help. Sorry it's so small. Replaced gpr and truck died! Need help!!!-imageuploadedbyautoguide1353861290.547266.jpg
Old 11-25-2012, 07:43 AM
Also tach does not move when cranking...buzzin/clicking is still happening
Old 11-25-2012, 08:05 AM
Did you swap your cps yet? If not then do it.
