White smoke Codes - Ford Powerstroke Diesel Forum
Old 11-20-2012, 07:17 PM
White smoke Codes
Well, I have been perusing the forums for an answer to the "White Smoke" problem and haven't really found a solution for my truck. Any temp below 65 degrees or so and my truck smokes white and smells of diesel from anywhere to 3-7 minutes at idle until oil temp reaches 70* or so. I checked my GP's and everything checks out nicely, I installed a Stancor relay, I have a glow plug LED mod so I know my glow plug system is working correctly. I figured something with the fuel system might be wrong, so I talked to the local Snap-On guy and..
borrowed a new Solus Ultra scanner from him, ran a buzz test and CYL. Contribution test. Buzz test checked out good, CYL Contribution test showed CYL 8 was weak. After some research I found that alot of people say to ignore the cyl 8 failure on a cyl. contribution, because it fires right after 7?, and is a split shot injector to reduce cab noise. After finding all that out, I finally went and scanned for codes and checked live data.
Codes and live data revealed:
P0603 Internal Control Module KAM Error
P0113 Intake Air Temperature High input
P0284 Cyl 8 code (from the contribution test, not stored in memory)
p0476 Exhaust pressure control valve ckt range/ performance
Any thoughts or opinions on the matter? Live data for the IAT sensor claimed -40*F So I am wondering if maybe it is overfueling after a start up? runs a touch rough until oil temp gets higher.
Thanks for the help!
-Nate
Old 11-22-2012, 08:46 PM
Anything folks? I'd also like to mention I have extremely poor fuel mileage. 11-12 MPG Highway @ 65 little wind. Boost was around 3 PSI and ICP was 1200-1500 Psi. Calculated engine load read off of my CTS was around 50%! that seems pretty high with no load cruising down the interstate.... does the EBPV ever get partially stuck shut? truck feels like it can brake itself to a stop after I let off the accelerator.
Don't think the turbo is at fault, when i punch it in lvl 2 race mode on the edge I can get 18-22 PSI of boost. Up pipes are leaking as well.
Truck details are in my sig.
Step up to the plate!!!!
Old 11-30-2012, 10:33 AM
Lightbulb Some thoughts
Hey, Naterenfo1...
We spoke several months ago on a thread I started when I was trying to work out the smoking issue on my 7.3 and I found that injectors 7 & 8 were bad. (By the way, I believe the reason 8 is different - beyond Ford's need to reduce noice - is that it actually fires after cylinder 6 (not 7) - the next door neighbor to the front on the same head - and that can "starve" fuel from the fuel line to cylinder 8 when it tries to fire.)
Anyway, having replaced injectors on 7 & 8, I have still noticed some smoke when I first start on a cold day and it goes away in 200 or so feet if I slowly drive away. If I let it sit and idle, the smoke simply gets too embarassing to put up with for very long. In any case, your 70 degree-F temp idea sounds plausible.
Because I am still not happy with the amount of smoke I'm still getting, I am going to pursue three more things.
First, I need to change my fuel filter. I bought the truck a few months ago and this has been on my "to-do" list. There is a chance that the guy that owned it before me may have used farm gas and one of my "experts" said that he has seen the dye from farm gas plate out on the filter and reduce its efficiency. In other words that could cause more smoke than usual.
Second, another guy told me that the water dump valve on the fuel filter could be leaking by the o-rings and allowing the system to actually suck in air during certain times of acceleration/deceleration. I've had another guy tell me that I shouldn't even use the valve because the more they are used the more they leak. I could be sucking in air from the suction side of the fuel pump too. Because I don't know what was done before I bought my truck, I will probably replace the water drain valve when I change the filter. I'll leave the pump possibilities for another time. See number three below.
Finally, three, I have looked into the whole air issue in the fuel system and believe I am going to install the fuel cross-over from Riff-Raff. It's a cheaper way to go than a full blown system and I can reverse the whole process (if needed) without having spent a fortune. The cross-over is designed to stop the "dead head" issues that threaten the 7.3's, it gives another path for the air to go so it can be dumped back into the tank, and it gives me the increased ability to "play" with the fuel pressure at the injectors to see if that changes anything. I have read that air can be a reason for the excessive smoke. Ford even states in their literature that air in the fuel lines can be a cause for excessive white smoke -- particularly when the engine is first started.
I think these things will always smoke a little bit when you first start them up and it is cold. I think the smoke is an inherent part of the design and that is simply what they do. I believe, in part, that is why I smell raw diesel and it all goes away after she warms up and begins firing more completely across the entire cylinder on the compression stroke.
My thoughts above are to simply try some things that 1) need to be done as part of routine maintenance, 2) aren't really things that could cause me any issues by radically changing the design, and 3) all can be reversed if I find a performance fall off or issue (neither of which is anticipated).
I've been too busy lately to chase any of the above changes and, to be honest with you, I can't get too motivated when the temperature outside is in the single digits. I will, however, work the changes soon and let you know if any of these things seem to help.
Hang in there...Sagemonkey
