BOOST - Ford Powerstroke Diesel Forum
Old 11-18-2012, 06:38 PM
BOOST
WHAT KIND OF BOOST SHOULD I BE SEEING? AT FULL LOAD I HAVE NEVER SAW MORE THAN 21. SOUNDS LIKE IT KEEPS TRYING TO GET UNDER TURBO CHARGER. SINCE INSTALLING COLD AIR INTAKE IT HAS STARTED THIS. TURBO HISSES REALLY LOUD AND BARKS ALOT. DO I NEED TO UPGRADE MY COMPRESSOR WHEEL?
Old 11-19-2012, 12:41 AM
Installing one of those shock collars may help with the barking problem .
Putting the cold air intake probably just made you able to hear the symptoms your describing and not actually causing them. WHat do you mean by get under turbo charger?
Old 11-19-2012, 03:00 AM
Have you ever been to a tractor pull and when they get to the end and under heavy load the turbo starts chirping? It like there is more exhaust pressure than intake pressure causing the compressor wheel the be pushed instead of turned.
Old 11-19-2012, 03:31 AM
It's just surge (if it's doing it under load) or the air coming back out if you just let off the throttle. Normal.
Old 11-19-2012, 03:39 AM
Ok so i turn my programmer off and i can only build 14 lbs of boost. Ive got something wrong. It wint get out of its own way.
Old 11-19-2012, 07:22 AM
With no tuner... I can rarely get my turbo to spool to 16lbs.
Old 11-19-2012, 12:54 PM
Ok so check for exhaust leaks, boost leaks, or a sticking EBPV. Also, how are you reading boost?
