random stalling, 1999 VAN 7.3L - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-16-2012, 10:29 AM Thread Starter
for the past 2 or 3 weeks this cube van dose random stalling, today it stalled as I was at a red light sitting still, it started right back up, then it stalled again when I came to a stop waiting to turn onto another street, again started up no problem, this time the service engine light came on... when I parked the van and started it back up in my parking lot the service engine light was gone and never seen it since, took it for a good drive and it never stalled at all was running like it was a brand new van...
this is the 1st time I ever seen the service engine light but its off now dunno why but it just is, I thought I would have to rest the computer to turn that light off but it seems to have turned off on its own from just doing a restart...
but I do get random stalling every now and then ... its really hard to know when its going to happen... could be 1 time 1 day or even 2 times... then never again for a week....
I have been told to change the CPS and ICP sensor's but I have no clue if that's going to fix my problem or not... I would like everyone's input please... I don't even know where to find the sensors..
I had a emissions test done about 2 months ago the result was 1.3 the limit was 30.0, the guy that ran the test told me that the test basically says my 7.3L engine is running as good as it was the day it came off the line and told me from his experience that the engine sounded mint.
When I leave the truck sitting over night it never has a problem starting and dose start very fast, there is no smoke coming from the muffler, just a small clear very faint white look for about 5 seconds, its just moisture I'm sure.. after that its very clear/clean looking.
its a cube van 1999 e450 7.3L powerstroke with 268,000km I will add a photo to show what it looks like.
lndn is offline
post #2 of 3 Old 11-17-2012, 03:59 PM
PowerStroke_Lover's Avatar
Stalling Problem
I would say check your PCM pwoer relay or it could be a faulty ignition switch but intermittent things like this are very hard to track down you might also try swapping the PCM power relay with your blower relay and check all your connections to your fuse box as a start.
1999 F-350 Lariat 4x4 extended cab short bed single rear wheel locking hub 6speed manual 4.5inch lift Eagel alloy wheels 4inch flowmaster downpipe 4inch exhaust into side dump 5inch xpd se tip pyro pre turbo and boost gauge #6637 DIY Intake custom built box for 12inch subs and 2400 watt amp kicker comp 6x9 speakers in the doors
OIF 02-22-08 to 08-10-08
MEU 03-20-10 to 11-11-10
Semper Fi DEVIL DOG
PowerStroke_Lover is offline
post #3 of 3 Old 11-24-2012, 06:10 PM
ford did a recall on crank sensors. i think if i remember right the crank sensor had something to do with stalling. the updated sensor is a different color than the old ones.
northern1 is offline
